Engine rotation
I have a 1998 7.4 mercruiser Bravo1 long story short I'm installing a new raw water pump and can't figure what way the impeller fins need to go. Not sure what rotation my engine is either and serial # is worn off... Any help would be so appreciated
With the plastic housing in your left hand. Twist the impeller into the housing clockwise. put the impeller on the shaft of the belt pulley, soap it up and twist in holding on to the belt pulley
