Mechanical fuel pumps gph? >
Old 05-25-2014 | 05:37 AM
vintage chromoly's Avatar
Default Mechanical fuel pumps gph?
Hello all.
I'm putting together a 517cu in. Bbc engine.
Big brodie heads and brodix hvh intake
900 cfm carb
Approximately 700 hp
Looking at the holley mechanical fuel pumps and I'm not sure I I should go with the 110gph or the 130gph.
Any thoughts?
Thanks, rob
vintage chromoly is offline
Old 05-25-2014 | 07:54 AM
TomFTM's Avatar
Go with the 130 pump. Much nicer pump.
TomFTM is offline
Old 05-25-2014 | 03:28 PM
Check out the CV Products BBC billet mech FP. Our NA engines are 780 HP and we hold 6.5 lbs FP at WOT with no return lines needed. We installed a 1/8" pipe fitting in the top of the CV pump to re-route any fuel to the flame arrestor/carb if the FP diaphragm was to rupture. This should be close to bolt-on with little or no re-rigging required.
BenPerfected is offline
Old 05-25-2014 | 03:50 PM
Thanks guys!
Ben.....I'll call CV on Monday. I just bought some two pin gilmer pulleys from them for my dry sump setup. Awesome folks at CV for sure.
Old 05-25-2014 | 05:24 PM
mmb
I ran Clay Smith on my blower engines 925hp. They work perfect! Very nice 6 valve 140gph pumps.
http://www.claysmithcams.com/fuel-pumps/
mmb is offline
Old 05-25-2014 | 05:46 PM
I'm assuming you regulated it down.
It says it puts out 14psi.
Thanks for the link. Looks like a nice pump and price is great.
Also, did you somehow vent it to the carb?
Old 05-26-2014 | 09:44 AM
mmb
Tell them you need the marine pump and it will come with a vent. Yes I have a regulator on my set up!
mmb is offline
Old 05-26-2014 | 09:50 AM
mmb
Here is what the pumps looked like installed on my engines.
mmb is offline
Old 05-26-2014 | 12:28 PM
SABER28's Avatar
anyone use those holley billet pumps? why are they so expensive? $450+ ?
SABER28 is offline
Old 05-26-2014 | 01:06 PM
SB
That's what the Ultra's (200+GPH free flow) cost : http://www.jegs.com/p/Holley/Holley-...34184/10002/-1
The HP Billet's (170GPH free flow) are $299.00
BTW, thanks. I did not know the Ultra's where available yet. I must be behind the times and getting old. LOL.
SB is offline
