spark plug change time any tricks
loosen with 3/8 ratchet,,,then switch over to 1/4 ratchet,,,,use a piece of 3/8 fuel hose about 8ins long ,slip it over top of plugs to remove old plugs and install the new plugs using the fuel hose also
Lift your hatch ALL the way up vertically. Suspend it from a rafter or something above. Put a moving blanket on top of the motors and lay across them for better access to the back cylinders. On my boat, (not a 32 Fountain), this turned a 4 hour job into a 2.5 hour job.
Like sydways said. Lay on top of motors. Rear plugs easiest to reach from back of motor. Not that bad of a job.
I also remove the rubber insert from the plug socket. Never fails after tightening the plug and you go to remove the socket, the extension comes off the socket cause the rubber has a better grip.
