03 496 ho double beep >
Old 06-11-2014 | 05:20 AM
Default 03 496 ho double beep
I've got 496 hos had the injectors cleaned i put them back in and now i have a double beep that was not there before i did them. Any ideas???
Eleanor is offline
Old 06-11-2014 | 06:16 AM
F-2 Speedy's Avatar
Can you give us some more info. ?? at start up after running, two longs and a short, LOL whats the intervals/ cadence of the beeps.
F-2 Speedy is online now
Old 06-11-2014 | 08:02 AM
At start up and while running. 2short beeps. Haven't driven it since it started.
Eleanor is offline
Old 06-11-2014 | 08:03 AM
It's about every minute or so
Eleanor is offline
Old 06-11-2014 | 08:20 AM
F-2 Speedy's Avatar
Does the engine run fine ? try unpluging the MAP sensor and reconnecting it
Old 06-11-2014 | 08:26 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
If you guys can tell me why the Check Engine Light is illuminated on my neighbor's Toyota, I'll tell you why your PCM is beeping.
It's pretty much a futile effort to try and diagnose these things sans Diacom software, Rinda Scanner, or SmartCraft gauges.
It could be an IAC, but I strongly suggest getting it scanned or acquiring a scanner. It's the best $500 you will spend on your boat. Split/share the costs with your neighbors/buddies, or rent your scanner out to recoup costs.
Sydwayz is offline
Old 06-11-2014 | 08:57 AM
F-2 Speedy's Avatar
Id have the Ti Ota scanned as well, could be low water flow
Old 06-11-2014 | 10:51 AM
Engine runs fine
Eleanor is offline
Old 06-11-2014 | 10:57 AM
BUP
One of the worst things you can do now is keep running with an active fault / alarm. Could be water pressure low and or sensor shorted or bad. A scan without a doubt is needed. IAC is a huge problem for most MPI Merc as well. Again a diagnostic scan will determine or least point you in the direction of what area needs attention.
BUP is offline
Old 06-13-2014 | 04:13 AM
bought a scan tool, it arrivedd yesterday. # 7 fuel injector open . thanks for the help guys!
Eleanor is offline
