Bilge Pump Fuse on 280 >
Old 06-14-2014 | 10:16 AM
Default Bilge Pump Fuse on 280
Since I bought the boat there was a inline fuse and a spot for a spare connected to the battery. There was never a fuse in it. The pump works from the switch at the dash but while I was filling the bilge with water to clean it I noticed the pump didn't go on by itself. Could this be for the pump float? And if it is what size fuse goes there?
Hotdog1922 is offline
Old 06-16-2014 | 07:09 AM
Revelocity's Avatar
Although Velocity generally didn't connect the float switch directly to the battery - this is a tried and true approach. While the fuse size depends on the pump size, I'd suggest trying a 10 amp and moving up as needed.
Revelocity is offline
