Mercruiser Head Gasket Sealing >
Old 06-16-2014 | 12:07 PM
CIG3's Avatar
Default Mercruiser Head Gasket Sealing
I'm putting a 228 Merc together for a friend. He dropped off everything including the gasket set. The head gaskets are coat stamped steel. What if anything should I use on them to seal things up? I figured just a little hy-tac or something around the water jackets.....
CIG3 is offline
Old 06-18-2014 | 08:25 AM
I would not use steel gaskets in a marine engine, use felpro...the steel will rust away with out fresh water cooling which I'm betting this does not have...
ezstriper is offline
Old 06-18-2014 | 09:32 AM
i agree,fel pro marine head gasket is the way to go.
mike tkach is offline
