Bravo 1 getting harder to get into reverse >
Old 06-19-2014 | 07:07 AM
Default Bravo 1 getting harder to get into reverse
98 stock bravo 1 is starting to get harder to get into reverse, checked cable from shifter back and works smooth, so issue in drive or rear cable, been using royal purple fluid..any idea's ? thanks Rob
ezstriper is offline
Old 06-19-2014 | 07:42 AM
Mr Gadgets's Avatar
Charter Member #601
Pull the back cap and make sure the detent ball is not coming apart, and make sure it is lubed good. How is the cable from the transition block to the drive?
Dick
Mr Gadgets is offline
Old 06-20-2014 | 08:31 AM
Thanks Dick, will do...not sure on the cable at that end..
Old 06-20-2014 | 08:43 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Shift cable adjustment procedure included here:
http://www.boatfix.com/merc/techbk/94/94hg2a.pdf
Could be part of the issue.
Sydwayz is offline
Old 06-20-2014 | 10:08 AM
pulled the cap, ball where rides looked funky, but there is a lot of slop in the pin where the cable link attaches to the arm...had one of those where thru before, so guessing thats worn as well...
