29 fever with twin 454s both leaking on lower port side of motors >
Old 06-19-2014 | 06:34 PM
Default 29 fever with twin 454s both leaking on lower port side of motors
Fired up the ole girl at the ramp and to my disgust both motors are leaking water from the lower (under) side of the engines. Both are leaking from the same (port) side. Is this some type of heat exchanger that I can't hardly see? It appears to be some type of black plastic cover with a few hoses running in and out that the water is coming from. Can this be fixed from inside the boat or am I going to have to pull motors?
fordf350 is offline
Old 06-19-2014 | 06:39 PM
Was it winterized properly?
12meter joe is offline
Old 06-19-2014 | 08:11 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Check the blue drain plugs there. Cool fuel unit
US1 Fountain is offline
Old 06-20-2014 | 06:08 AM
Have to see if I can get down in there. They sure don't make it easy.
fordf350 is offline
Old 06-23-2014 | 10:49 PM
Almost sounds like a freeze plug. Im like the other guy did you winterize them? I didn't look were you live did you have freezing weather this winter?
Lucky1456 is offline
Old 06-24-2014 | 05:27 AM
Cracked Impeller housing??
Greatguy66 is offline
Old 07-09-2014 | 01:16 PM
I just can't my $$$ down in there to see. It looks like the fuel cooler area. Outdrive is out and pulling the motor...
fordf350 is offline
Old 07-09-2014 | 08:54 PM
Ginger or Mary Ann?
you are pulling the motor to replace the plastic drain plugs?
Old 07-09-2014 | 09:22 PM
No. It appears to be coming from behind the cooling tube
fordf350 is offline
Old 07-11-2014 | 11:47 AM
There is a drain plug in that cooler. It could be leaking.
Interceptor is offline
