Best place to buy trailer axles? >
Old 06-24-2014 | 12:18 PM
Rookie's Avatar
Default Best place to buy trailer axles?
Looking to see where people are getting their trailer axles.
I have 3-3500lb axles on my trailer and looking to go to 2-6000lb torsion axles.
Ebay custom order and drop shipped to my shop??
Rookie is offline
Old 06-24-2014 | 01:28 PM
http://www.expediter.com/pdf%20folde...folder/B33.pdf
http://www.northerntool.com/shop/too...20&Search.y=20
30ftpanther is offline
Old 06-24-2014 | 01:39 PM
I can handle that for you. Give me a call. 901-491-4500
payuppsucker is offline
Old 08-12-2014 | 09:14 PM
Rookie's Avatar
My 6000lb torsion axles, new rims and tires arrived Monday. Big difference from my 3500lb. Can't wait for the weather to break so I can tear off the original setup and get these on. These are 6000lb Torflex straight from Dexter. Breaks and drums should be here by Friday.
I'll add pics of the makeover as I make progress.
Rookie is offline
Old 08-13-2014 | 10:37 PM
Rookie's Avatar
I still can't get over the sheer mass of these 6000lb axles. I have everything minus fenders, the dexter brakes and bearings arrived 2 days ahead of schedule.
[ATTACH=CONFIG]527887[/ATTACH]
[ATTACH=CONFIG]527886[/ATTACH]
Attached Thumbnails Best place to buy trailer axles?-20140813_191601.jpg   Best place to buy trailer axles?-20140813_191551.jpg
Rookie is offline
Old 08-13-2014 | 10:47 PM
Rookie's Avatar
So the fun begins. My brother and I started disassembly of the trailer. [ATTACH=CONFIG]527888[/ATTACH]
[ATTACH=CONFIG]527889[/ATTACH]
Rolling triple assembly removed.
[ATTACH=CONFIG]527890[/ATTACH]
It is pretty much wasted. I'm glad it only goes a couple miles to the launch.
[ATTACH=CONFIG]527891[/ATTACH][ATTACH=CONFIG]527892[/ATTACH]
Attached Thumbnails Best place to buy trailer axles?-20140813_183337.jpg   Best place to buy trailer axles?-20140813_183406.jpg   Best place to buy trailer axles?-kimg0029.jpg
Best place to buy trailer axles?-20140813_190608.jpg   Best place to buy trailer axles?-20140813_190617.jpg
Rookie is offline
Old 08-13-2014 | 10:57 PM
Rookie's Avatar
Back to work.
[ATTACH=CONFIG]527893[/ATTACH]
[ATTACH=CONFIG]527894[/ATTACH]
[ATTACH=CONFIG]527895[/ATTACH]
Before I arrived home tonight, the UPS man must have made a visit.
[ATTACH=CONFIG]527896[/ATTACH]
Attached Thumbnails Best place to buy trailer axles?-20140813_194334.jpg   Best place to buy trailer axles?-20140813_205951.jpg   Best place to buy trailer axles?-kimg0033.jpg
Rookie is offline
Old 08-13-2014 | 11:02 PM
Rookie's Avatar
Everything is now clamped on and I need to double check my axle spacing for going from a triple to a tandem. All suggestions welcomed.
I was going to use the center spindle of the triple axle carriage as the center mark between my tandem spindles. It makes logical sense to me.
Rookie is offline
Old 08-14-2014 | 05:47 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Nice work so far.
How much of the boat is aft of the main trailer support beams when loaded on the trailer? You might take this opportunity to move the boat forward as it looks like you have the room.
I know this complicates things, but this would be much better for your hull to be supported by aluminum instead of just that aft 3' section of wood.
Also, I would take the time to add a pair of front V-bunks from the carpeted cross-member, to the cross member at the start of your large bunks. This will help you load much better.
You can buy all the supports for the 2x6 V-bunks from www.championtrailerparts.com
Last, you really can't mount your fenders until you have the boat back on. I think you are going to sit a shade lower with the new axles. And, those torsion axles rotate back a hair when loaded. You want the fenders centered over the axles when the boat is loaded, not when unloaded.
Sydwayz is offline
Old 08-14-2014 | 10:07 AM
Solid info ^^
Looks like if you removed the spare tire (or used the same mount, just flip it over so the tire is underneath the trailer) you could move the winch stand forward, and then adding the front V bunks would help get the stern actually on the trailer not just the main bunks like Brian was saying.
TooLateVTEC is offline
