New Mallory Ignition, no spark
I replaced my stock distributor, coil and plug wires on my '99 5.0L with a Mallory 8160m distributor, Mallory 8207m coil and MSD 8.5 plug wires. I removed the wires from the old coil and installed them on the new coil along with the black wire and orange wire from the new Mallory connector. Black wire to - and orange to + side. I connected the old white/green wire (hot when key on) that connected to the original distributor to the red wire on the new Mallory connector. I left the original white/red wire that connected to the original distributor connected to nothing. I have 12v with the key on to the hot side of the coil and 12v with the key on to the red wire going to the distributor. Crank it over and no spark on the coil wire and obviously spark plugs. What am I missing? The boat stared fine before changing distributor.
Sorry, just looked up install instructions online and it states: Red wire to coil + Orange to coil - and black to ground. Looks like I've got some wires to change in the morning. I'll post an update after changing the wires around but I'm sure it will work when connected correctly.
Is it going to cause any issues not having anything connected from the module that was connected to the original distributor? The white/green and white/red wires.
Thanks guys, it's amazing what happens when it's hooked up right. I don't know why the connection instructions weren't included with the dizzy.
I left the white/green and white/red disconnected from the module.
Just an FYI, I leave the blowers on the whole time we are out to suck as much heat as possible out of the engine box and my water temp runs between 170-180 degrees. I've also always had a problem with the idle creeping up as we are out doing water sports and the 4bbl done the same thing.
