TRS Tail stock
Old 07-01-2014 | 07:39 PM
Default TRS Tail stock
Need. Tail stock for TRS setup. Installed two plugs in mine in three years, still leaking transmission fluid 252-339-4560
Harvey is offline
Old 07-02-2014 | 07:39 AM
I have one. But why not just pull your tail stock off and replace the lip seal in it?
Ok I reread, not sure what plugs your referring to.
raisingkane is offline
Old 07-02-2014 | 11:11 AM
Pull your drive and look into tail stock, you will see a plug in it. When you install drive the shaft stops just before the plug. When plug comes lose it allows fluid in seep into bellows and past the seal and leak down transnom .
Harvey is offline
Old 07-02-2014 | 12:50 PM
Maybe I'm missing it be don't see a plug. If your interested in this one it needs new bushings and a rear bearing, make offer, never leaked
[ATTACH=CONFIG]525618[/ATTACH][ATTACH=CONFIG]525619[/ATTACH][ATTACH=CONFIG]525618[/ATTACH][ATTACH=CONFIG]525622[/ATTACH]
Attached Thumbnails TRS Tail stock-image.jpg   TRS Tail stock-image.jpg   TRS Tail stock-image.jpg
[ATTACH=CONFIG]525633[/ATTACH]
Old 07-03-2014 | 06:17 PM
TomFTM's Avatar
I think I have one , will check tomorrow.
TomFTM is offline
Old 07-08-2014 | 04:44 PM
What I really need is the short shaft with bearing on it that goes into back of transmission that the tailstock bolts against. Ant old transmission out there.
Harvey is offline
Old 07-08-2014 | 05:20 PM
MrCIG's Avatar
Charter Member#330
Clean bothe surfaces with brake Kleen then Put red lock title on the plug and press it in
Should hold
Mark
MrCIG is offline
