water in oil on fresh rebuilt 468 with m1 procharger intercooled.
fresh 468 with procharger with a 3 lbs pulley built by a local builder that has built motors for 20 + yeas. After breaking in owner found some water in oil and he is asking roughly about 10 grand less than what its worth. could the procharger be causeing this issue or should i stick to the normal procedure looking at intake gaskets, heads/ gaskets or water getting into motor from exhaust.
Thanks, Sam
Thanks, Sam
also hear is a parts list still tring to get cam specs.
steel crank
scat rods
arp hardware
gm performace heads ported and polished,
heavy duty springs and roller rockers?
custom ground cam,
4 bolt mains
weiland intake with holey carb
fast style fuel system with holley electric fuel pu,
aeromotive boost reference fuel pressure regulator
steel crank
scat rods
arp hardware
custom ground cam,
4 bolt mains
the only thing causing it procharger related is the intercooler might be leaking but that would cause a hydrolocked motor.. could be that the engine is running too cool and not burning off the condensation.
Didnt see aftermarket exhaust so my first guess reversion. How much water we talking? Little bit or full on milkshake with higher dipstick oil level? Had that with mine similar engine build minus charger 3 hrs later on rebuild turned out to be the intake manifold.
not real sure when i talked to the person they said noticed higher oil level on dip stick and drain then noticed it being pretty milky today going to look at it today but owner doesn't want to put the boat on the water just on muffs.
also reversion was my first thought as well.
I've seen people put in t-stats...which is a no no with the factory Procharger crossover set-up. The t-stat will block all water flow and the Bravo sea water pump will win. LOL.
However, there are many places water can get in from a 'newly' rebuilt motor and a used one for that matter.
Buying a "troubled engine" because you can get it cheap?
Helping the "owner" fix his troubled engine?
Since you stated "owner" and not "buddy" I don't see the logic in either scenario.
