Just got a noise ticket tonight - need options >
Old 07-04-2014 | 02:47 AM
Default Just got a noise ticket tonight - need options
Having fun idling up the river in Milwaukee waiting for the fireworks show and I unexpectedly find out the DNR wasn't entertained by my exhaust. Apparently 95DB at idle is too much. Admittedly, the cam change, head work and fatter tune definitely made it louder. What ever dick head just give me my ticket and let me go back to having fun. So, now that I know the rules 86DB's, I need to make some modifications. Since i like loud and personally 95 DB is kinda weak, i'm considering going dry with some type of switchable muffler. If i'm going to do this I might as well do it right. What is everyone using?
I currently have Stainless Marine Exhaust that I was planning on extending the riser to couple directly to a dry tip. Unfortunately, I haven't seen a dry tip yet. I would think these would still be water jacketed with a water dump right? Not trying heat the crap of my transom. A switchable / muffler tip (for dry exhaust) would be IMO the best option. Does this exist?
I comfortable making everything (rather not) except the muffler. I need confidence that a muffler will be quiet enough to get me through this crap without water flowing through it.
Signed - pissed off
abmotorman is offline
Old 07-04-2014 | 12:08 PM
I doubt you are actually at 95db and the test was most likely not done corectly.
Switchable mufflers added to dry exhaust will not make them quiet enough to pass a db test.
Dry exhaust does not go to a "Dry Tip" The riser/tailpipe is water jacketed and extends all the way through the transom.
BTW, 86 db will be hard to get to even with wet thru hull exhaust
Griff is offline
Old 07-04-2014 | 12:39 PM
Checked the DNR web site and sure enough 86 DB (see pg. 12) they probably set it that low to increase revenue. I actually believe the readings. I say readings because he followed me about 2 miles with a sound gun. Once we tied up in a nice open spot he pulled out the tape measure and separate meter with a fancy dancy mic on it and proceeded to document the whole experience on video. yep i'm screwed.
Are you saying you haven't seen an effective, muffler (preferably switchable) for dry exhaust? Someone has to make something??? I see some running turndown's that discharge below the waterline while not on plane. Still see them giving me crap about that.
http://dnr.wi.gov/files/pdf/pubs/le/le0301.pdf
Old 07-04-2014 | 02:11 PM
the turndowns will do the trick. you can try a half-ass version. clamp merc thru-prop elbows on ends of exhausts if tips are within 8 inches or so of water at idle.
dereknkathy is offline
Old 07-04-2014 | 04:19 PM
Wobble's Avatar
SORE MEMBER
+1, turndowns seem to be the most common solution
Wobble is offline
Old 07-04-2014 | 04:25 PM
Yep. Show them the money. That sucks though.
thirdchildhood is offline
from what i understand he is soppose to do the db test out in the middle of a lake with out anything near your exhaust to rickashay off of...i have been pulled over too,,i wait i use to wait for the officer to get set up and told him that he was doing it wrong and pulled out the paperwork..then i showed him the piece of paper that showed him my older boat that 1980 is grand fathered in to have louder exhaust..
FIXX is offline
Old 07-04-2014 | 11:27 PM
Anybody have experience with either of these systems? To me the electronic would be easier and lighter. Pneumatic maybe prone to long term corrosion concerns???
http://teaguecustommarine.com/em0011...er-system.html
http://www.cpperformance.com/p-12615...encer-kit.aspx
Wonder how much reduction in sound on a dry setup?
http://marineexhaust.ggb.ca/4-inch-i...ong-sport-pair
Old 07-05-2014 | 06:40 AM
Saratoga Stamped's Avatar
Signed - pissed off
I have spent money on all the options in the past. Clearly the I found gettting a set of turn down pipes may be the best overal option: it is quieter on idle, runs great on top, and can easily be removed when you go to a different location or for other events. Besides the clamp on versions, drill a hole in the tail pipe to allow a secure fit with a simple lock bolt also.
It happens
Saratoga Stamped is offline
Old 07-05-2014 | 07:03 AM
jeff32's Avatar
on my formula with silent thunder ''wet'' swim platform, on twin 485 HP, my db reading was 91-92, at idle, 3 feet behind and 3 feet high.
I don't see any boat being able to be under that without turn down !
jeff32 is offline
