42 fountain prop help >
Old 07-04-2014 | 07:20 PM
Default 42 fountain prop help
Boat runs great with 32 pitch 4 blades. Tough to get on plane, but decent overall. Tried a stock set of maximus 30 pitch, hoping to get on plane better, and have better midrange. Results are not what I expected. Almost impossible to get on plane. The boat keeps blowing out anywhere over 3000 rpm. Under 3000 rpm it does not want to pick up speed to plane off. Have tried tabs in all positions, drives are tucked. Usually 4 people, and 100 of fuel on board. 2004, 525 boat.
dlange is offline
Old 07-07-2014 | 01:52 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Strange. Do you have any history on the props?
Have they been repaired or worked?
Brtt
[email protected]
bbladesprops is offline
Old 07-08-2014 | 10:31 PM
Thanks for chiming in Brett. Stock maximus 5 blade 30's. full diameter. No repairs or work I'm aware of. I switched back to 4 blades just to make sure I didn't have other issues. They were fine. It was a 1/2 mile balancing act to get the boat on plane with the maximus props. Could my drive showers be to close causing cavitation or something? Just thinking out loud.
dlange is offline
Old 07-09-2014 | 07:18 AM
Getting more blowout from the maximus props over the bravo 1's seems strange for sure. It would almost seem like you need higher pitch but it totally makes sense to go from 32 Bravo's to 30 Maximus..
What drives / lowers are on your 525's? Is it a full stagger? If they are short sportmasters, you might have to remove the splash plates using full diameter maximus props. I've had good results with the max's. Went from 6-blade Herings to max's and got less blowout.
HyFive578 is offline
Old 07-09-2014 | 01:01 PM
Standard drives. I would guess my drives are a touch deeper than most 04-05's. boat is a full stagger.
dlange is offline
Old 07-09-2014 | 01:33 PM
That is very strange. Are you 100% certain that the max props you have are box stock? I recently bought two maximus props from someone who told me the "only" thing they did was take them down to 15 1/2 diameter. I ran those props and got terrible results. I then ran the out-of-the-box stock maximus props there was a 10 mph difference and planing and handling was totally different and I thought the "only" difference was 1/8" diameter. No complaint about the seller I bought the props from because they disclosed that previously, but I couldn't believe there would be such a difference and there was. If you're certain they are stock, then I'm stumped. You might try removing the water pickup from the drive shower to see if that makes a difference but put a cap bolt in there with a nut on top of the cavitation plate so you don't leave a hole in the plate.
Old 07-09-2014 | 05:51 PM
I agree with HyFive that it seems there might be some "repair work done to the Max props.
Also, I don't like to install drive shower pick ups more than 1/2" below the cav plates. I'll go shorter if possible. They can cause a cavitation bubble that can disrupt the high pressure on the face of a propeller blade upon planning or once under way.
Brett
[email protected]
Old 09-17-2015 | 03:49 PM
Did you ever try new stock 30 maximus props and get results? Thinking about the same thing.
joew. is offline
Old 09-24-2015 | 08:35 AM
Any updates?
joew. is offline
Old 09-26-2015 | 08:48 PM
I'm running 30 maxs on my 04 with 525. Drives are sport master shorties with 1 inch spacers. Had to put them in because stock maxs would hit cavitation plate. Had BBlades cut and rework them to work without spacers. Boat runs stronger and has more mid range acceleration than before.
Next is to take spacers off and try that. Planes great with the 30s, much better than the bravo 32s.
SLOWRIDE-388 is offline
