Converting from single control to dual stick controls? >
Old 07-05-2014 | 05:59 AM
Default Converting from single control to dual stick controls?
Hi all,
I'm thinking of converting my sigle stick control to a dual stick control on our Baja Islander.
One,
has anyone done this?
Two,
this is a side mount that will be coming off so a side mount/pod system will be needed.
Three,
Any suggestions?
I found this unit for sale but was wondering if there was a little different/cheaper set up?
http://www.monstermarinestore.com/pr...d=1453&incat=7
The unit above looks very nice but its a bit more than I really want to spend at this point.
Thanks in advance
Jeff B In Maine
Rubrsidedown is offline
Old 07-05-2014 | 06:03 AM
I think in order to convert side mount to separate shift/throttle you would have to build a box to mount it in. Your link didn't open for me. Other than that its am easy swap. Controls are expensive.
Crude Intentions is offline
Old 07-05-2014 | 09:08 AM
link doesnt work. i am assuming you want something like these.
http://www.cpperformance.com/p-65184...t-shifter.aspx
http://www.cpperformance.com/c-842-d...-controls.aspx
the problem with building a box to mount the normal ones is the angle you would have to have your cables coming out at to no be a complete eyesore. at least not any uglier than the random box just hanging on the side of the boat.
beaver 3 is offline
Old 07-05-2014 | 10:11 AM
there is also a Teleflex one 620 on ebay but has little brown and black knobs like a sportfisf control.
dereknkathy is offline
Old 07-05-2014 | 11:15 AM
Would you happen to have a link to the Teleflex unit on Ebay?
Beaver 3 found what I was looking into. Those things aren't cheap.
Old 07-05-2014 | 12:21 PM
just go to ebay and put Teleflex dual lever throttle in search box
Old 07-05-2014 | 08:00 PM
I could only see 3 units up online and none of them look anywhere near what I would want
Thanks anyway
Old 07-07-2014 | 05:56 PM
Livorsi makes some really nice looking single side mount levers that would be a nice upgrade without a lot of extra work and reconfiguration.
bustedbrick is offline
Old 07-08-2014 | 05:53 AM
Thanks, and Yes they do look nice but it doesn't look as though they include a trailer switch on their set up, the Dana dual control does.
I MAY have to spend the LONG dollar in the future to get what I am looking for. (as much as I hate too)
Thanks for chiming in though, I greatly appreciate it.
You never know, someone might have already done what I'm looking to do with something a little different for le$$ than the Dana set up.
Jeff B In Maine
Old 07-08-2014 | 06:02 AM
Jeff B In Maine
