2 502's 2 454/420's and lots of other stuff >
Old 07-12-2014 | 07:48 AM
Default TRS STUFF 2 502's 2 454/420's and lots of other stuff
ALL STUFF LISTED IS FOR SALE. READ MY POST UNDER 1984 MIRAGE IN THIS SAME FORUM AND IT GIVES MUCH BETTER DETAILED DESCRIPTIONS.
2 454/420'S LOW HOURS UNDER 60, 1- 502 REBUILT, (1 502 LOW HOURS, GREAT COMPRESSION BUT SITTING FOR A WHILE. 1-502 SOLD)
4-TRS GIMBALS, 2-REBUILT, 2 LITTLE PLAY Fresh Gimbals $1100
4 TRS OUTDRIVES 2 NICE (sand blasted need to be painted) I purchased these because very good cosmetically and I knew who maintained the boat. ,Nice pair $2500 Ugly but functional ( more electrolosis divots than I like) $1800
2 O.E.M TRS DECAL SETS. YES I WAS THE AH THAT PAID $400 FOR THEM!!! OFFERS
2 NEVER MOUNTED HOLLEY 800CFM-CARBS SOLD!!
1 DART HP 500 STYLE INTAKE AND 800CFM EXCELLENT AND POWDER COATED BLUE $600
1-SET SHIFTER AND THROTTLES W TRIM SWITCH OUT OF AN EARLY TOP GUN, CLEAN $300
4 GIL MANIFOLDS, 4 RISERS LOW RISE LONG DRY 1-set Manifolds SOLD
2 HOLLEY BRAND NEW BLACK PUMPS
FULL SET GAFFRIG GAUGES FROM OLDER FOUNTAIN WITH TWINS- OFFER
1-168731 CRANE CAM ,DYNO TIME $200 1-SET CRANE GOLD ROLLER ROCKERS FOR BBC, LOW HOURS, W/O LOCKS $175
HERE ARE THE SPECS FROM CRANES WEBSITE:
1996 Up CHEVROLET 8 FAIR IDLE, MODERATE PERFORMANCE USAGE, GOOD MID-RANGE TORQUE AND HP, MILD BRACKET RACING, AUTO TRANS W/2500+ CONVERTER, MILD MARINE PERF., 3000-3400 CRUISE RPM, 9.5 TO 11.0 COMP. RATIO ADV. BASIC RPM 2500-6000
Engine Size Configuration ?
454-502 C.I. V ?
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 345 @Valve 587 All Lifts are based
on zero lash and theoretical rocker arm ratios.
? Exhaust @ Cam 359 @Valve 610
Rocker Arm Ratio 1.70 ? ?
Cam?Timing: TAPPET @.004
Lift: ? Opens Closes ADV Duration
? Intake 33.0 BTDC 75.0 ABDC 288 ?
? Exhaust 82.0 BBDC 36.0 ATDC 298 ?
Spring Requirements: ??Triple?? Dual?? Outer?? Inner
Part Number 99896
Loads Closed 132 LBS?@ 1.906 or 1 29/32
? Open 405 LBS?@ 1.326 ? ?
Recommended RPM range with matching components
Minimum RPM 2500
Maximum RPM 6000
Valve Float 6500
Cam?Timing: TAPPET @.050
Lift: ? Opens Closes Max Lift Duration
? Intake 6.0 BTDC 40.0 ABDC 107 226 ?
? Exhaust 55.0 BBDC 1.0 ATDC 117 236 ?
1- RITCHIE COMPASS BEZEL IS CLOSE TO MERC RACING BLUE $175
1- NEW IN THE BOX MARINE WATER PUMP FOR BBC MES PART NUMBER WP415-M- $85
1 SET 4 BLADE BRAVO PROP 26P . DECENT CONDITION NO GOUGES AND NO BENDS. $500/PAIR
ALL PRICES ARE PLUS FREIGHT OR CAN I CAN ARRANGE TO DELIVER THE LARGE STUFF ANYWHERE ALONG I95 FROM N.J. TO LAUDERDALE SECOND WEEK OF AUGUST.
IF MAILBOX IS FULL TEXT ME AT 609.226.4485
86 apache 22 is offline
Old 07-12-2014 | 08:40 AM
Love to have that 502 but stupid house funds took my toy money!
KRAUSMOTORSPORTS is offline
Old 07-12-2014 | 09:24 AM
How much for 800 holley ?
daleroger is offline
Old 07-12-2014 | 10:44 AM
F-2 Speedy's Avatar
interested in the throttle and shifters, are they painted, or plated, alum ect
F-2 Speedy is offline
Old 07-12-2014 | 11:04 AM
shifters are stock black, original
Old 07-12-2014 | 11:06 AM
$250 a piece
Old 07-12-2014 | 12:13 PM
pmed u give me a call 609 259 3273 rich
scarab50 is offline
Old 07-12-2014 | 01:50 PM
SBX
Interested in either one of the holleys.....or the hp500 setup....can you get me prices shipped to 77662 please...funds in hand.
1 DART hP 500 STYLE INTAKE AND 800CFM EXCELLENT AND POWDER COATED BLUE
SBX is offline
Old 07-12-2014 | 05:22 PM
Irishtornado is offline
Old 07-13-2014 | 12:35 AM
how much for the shift are they still available pm me
pantera 30 is offline
