Aluminum Intake manifold + salt brackish water >
Old 07-20-2014 | 09:20 AM
35fountain's Avatar
Default Aluminum Intake manifold + salt brackish water
I was wondering if anyone new how many years i can run brackish salty water in my Edelbrock air gap intakes before i start having leakage into the engine. I do rinse the engines on a garden hose after each use. This is the 4th season on the intakes. I want to catch it before there is a problem.
35fountain is offline
Old 07-20-2014 | 10:45 AM
I can't tell you in years but if you flush after every use should be fine. Mine is 5+ years. I run a screw in pencil zinc in mine too in the front port accessory hole.
Mr Maine is offline
Old 07-20-2014 | 11:53 AM
Craney's Avatar
Where can you get the pencil zinc from?
Craney is offline
Old 07-20-2014 | 12:26 PM
SB
May I suggest Hard Anodizing next time.
Also, Edelbrock is just starting to introduce (again) Marine Aluminum intakes.
See: http://www.edelbrock.com/automotive/...s/marine.shtml
SB is offline
Old 07-20-2014 | 12:41 PM
http://www.westmarine.com/buy/sea-sh...04_122_002_502
I just get them from a marine store in town.
Mr Maine is offline
Old 07-20-2014 | 05:57 PM
35fountain's Avatar
Doesn't that block the water in the manifold passage a bit. I like the air gap manifolds . The open air space from the Air-Gap design separates the runners from the heat of the lifter-valley cover. So, the air/fuel mixture stays cooler all the way to the heads, which produces a denser charge for more power. Hard anodizing great idea. How much does that cost?
Old 07-20-2014 | 08:18 PM
SB
$100-$150 for a 4bbl intake usually.
Most towns/areas have a place that can hard coat anodize. Hit the yellow pages.
Watch out - since it makes your intake electrically dead, you'll have to externally ground any sensors in it. Coolant temp sensor I just ground it's external metal housing. Easy enough. Can do it with some wire, a spade termial, and a hose clamp....lol...if you want to do it fast.
SB is offline
Old 07-20-2014 | 08:20 PM
SB
That's how Merc big block aluminum intakes where. Same as marine Merlin intakes, Holley Marine, and etc, etc,
SB is offline
Old 07-21-2014 | 06:07 AM
most of the time the passages are bad in 8-10 years
ezstriper is offline
Old 07-21-2014 | 06:34 AM
35fountain's Avatar
Is the entire manifold anodized or just the water passages. Right now I have the air gap manifolds with the endurashine finish. They have a chrome finish. I'll probably just replace them with the standard satin finish and coat them with an enamel clear coat
