Thru transom plate drive lube fitting leaking >
Old 07-20-2014 | 06:22 PM
Default Thru transom plate drive lube fitting leaking
Can't explain how much I hate the smell of gear oil! After rebuilding my drive last week I was hoping I would never have to smell it again. Then, this happens.
I have a leak right at the transom, plastic fitting that goes through transom. It is not the hose, which I will replace anyway. Curious if someone can guide me through changing this fitting? Looks that it is held on inside with a clip, which is terrible access. Do I need to remove the drive and gimble, or can this slip out with the drive trimmed up and turned to the left?
4bus is offline
Old 07-20-2014 | 07:02 PM
BUP
if you would like you can call me tomorrow or even tonite about how to fix this. That plastic fitting is a POS from merc and I have to change them all the time. especially when people change the u - joint bellows out. They break them all the time. They are PITA to get to especially for a big person. 817-658-7721 if no answer leave contact info will call you back within an hour. Do not take anything apart because you do not have to. I will tell you what tools you need to this easier and how.
BUP is offline
Old 07-20-2014 | 07:19 PM
It's not that bad to replace. Must likely you are going to have to pull drive and pull hinge pins. But if you got a lot patience and little hands you might get the new one in there. Have and extra e clip on hand. Put a rag under plastic fitting inside so when you pull e clip that holds fitting in it doesn't fall into never never land. Depending what exhaust system will determand how much room you'll have for yours to get e clip on and off. Sometimes you'll have to pull water intake hose off inside boat to get hands on clip. With out looking in manual I think you cut new hose to 10 1/2 inch.
Clustergear is offline
Old 07-21-2014 | 10:48 AM
Thank you BUP for the conversation, helped a lot......wish me luck!
4bus is offline
Old 07-21-2014 | 11:12 AM
BUP
Ron good talking with you. We share some of the same common interests. You seem to know what you are doing - you will have it done in no time. Are you going to the Buffalo PR ?
BUP is offline
Old 07-21-2014 | 12:07 PM
I will be in the buffalo run!
4bus is offline
Old 07-21-2014 | 12:36 PM
BUP
Me to but not my boat, catching a ride. I will store your number in my phone and call you beforehand plus you can call me anytime.
BUP is offline
Old 09-26-2014 | 09:50 PM
I think I have the same issue on mine. Any words of wisdom one can post? Shall I call you BUP?
imartin is offline
Old 06-02-2016 | 10:18 AM
Ran-Dom 32's Avatar
looking for advise in this as well, I have a buddy with a 38 Baja & it needs to be replaced , going to see if I can help him out tonight , BUP your PM box is full
Ran-Dom 32 is offline
