Alternative to Mercruiser engine water pump? >
Old 07-21-2014 | 08:01 AM
Default Alternative to Mercruiser engine water pump?
I see lots of you guys are able to cross reference parts to automotive items. I think I'm going to replace my engine water pump while I'm doing my impeller. What are you guys going with? It's an 86 350.
Jonesyfxr is offline
Old 07-21-2014 | 08:51 AM
don't use an automotive circ pump on a raw water cooled marine engine. You can google why
motor is offline
Old 07-21-2014 | 01:34 PM
Ok thanks. I wasn't sure if it was a possibility.
You need the marine unit for the stainless impeller and back plate.
Trash is offline
Old 07-21-2014 | 01:51 PM
Ok thanks!!
Old 07-21-2014 | 02:20 PM
BUP
And the internal bearing sealing is better corrosion resistance compared to the auto side.
BUP is offline
Old 07-21-2014 | 09:16 PM
Tinkerer's Avatar
I had a water pump go bad and just bought the auto version and pressed the NEW bearing assembly out of the new one and installed it in the boat one. Worked perfect and never leaked.
Tinkerer is offline
Old 07-22-2014 | 05:45 AM
Seems like a lot of trouble when a replacement marine pump is only 100 bucks or so.. mercury retail is 144.00
http://www.boatersland.com/sie18-358...FaVZ7Aod0D0ARw
QUOTE=Tinkerer;4157369]I had a water pump go bad and just bought the auto version and pressed the NEW bearing assembly out of the new one and installed it in the boat one. Worked perfect and never leaked.[/QUOTE]
motor is offline
Old 07-22-2014 | 08:31 AM
Thanks for all the help guys!
OSO to the rescue.....yet again!!
Old 07-22-2014 | 04:22 PM
BUP
And not sure about this as for this year but the Sierra water circ for V-6 and V-8 small blocks (the same pump used) was the exact same that mercruiser used . Cheaper in price on the Sierra side.
BUP is offline
