blowers
Old 07-23-2014 | 10:31 AM
Default blowers
can you check boost if motors are not under load or does the boat have to be in the water.
trannyjoe is offline
Old 07-23-2014 | 11:03 AM
SB
Under load.
In neutral, your throttles barely need to be opened to bring engines to redline. Throttles are the airflow / power regulator of your engine.
SB is online now
Old 07-23-2014 | 11:30 AM
A said, must be under load. Even the amount of load will affect boost pressure. I installed a 1" larger drive spacer on my Pantera. The prop bit so much more that boost presure went up 1.5#'s.
Griff is offline
Old 07-23-2014 | 01:19 PM
thank you for your help so in the water we go.
