Need part # for seal on water pump. >
Old 07-22-2014 | 11:39 PM
buck183's Avatar
Default Need part # for seal on water pump.
I have mechanical fuel pumps that run off my water pumps. The seal behind the pulley has failed allowing all of the lube to leak out of the pump. I'm told I can rebuild it by pulling the pulley and pressing in a new seal. I hope this is the case. $500-700 for a new assembly doesn't appeal to me right now.
Anyone have a clue what a part number for the seal would be? Are there lots of different options depending on which one I have? Do I just need to remove the old one and use it to size up the replacement seal?
Buck
buck183 is offline
Old 07-23-2014 | 12:42 AM
Looks like you would need part #19
http://www.mercruiserparts.com/Show_...SEA+WATER+PUMP
Griff is offline
Old 07-23-2014 | 02:42 AM
Buck
Does the oil smell like gas? If so I would also recommend you replace the bearings. I use to have this setup before going to EFI/serpentine setup. I have two new GLM seals in OEM packaging if you want them for free. Just pay the shipping which probably won't be hardly anything. These pumps are actually very easy to rebuild. Here's a couple pics of the one I rebuilt.
Borgie is offline
Old 07-23-2014 | 06:14 AM
very easy job to rebuild pump ..you actually need 3 seals 1 in the front 2 in the back take care to notice the dir the seals are in the rear..
as i remember brgs are #6204 $2.50 each from mc master carr .seals i always buy from merc dont think u can get the stainless seals anywhere else .. if you smell gas in the oil it does not mean your pump is bad >>they all do it its very common
smokin' gun is offline
Old 07-23-2014 | 06:51 PM
buck183's Avatar
Gentlemen, these were all very helpful replies. Thank you.
I got a little gun shy when I saw what the problem was and realized how much a new assembly cost. Glad to know these things are serviceable.
My goal right now is to pull the seals and see if a local parts store has some that will match up to get me by. If not, then I guess I'm down another weekend until I order the parts in from Merc.
Borgie, if things don't work out on my end locally I may take you up on that. Thank you for the offer.
Smokin Gun, hopefully I don't shoot myself in the foot for buying none Merc parts if I can find them. I'm kind of in a get by mode right now.
Griff, thanks for the link. Hoping that will help me cross reference the seals at a local parts store. Sometimes those numbers have some sort of size in them that help cross them over.
Buck
buck183 is offline
