Pitch Change? >
Pitch Change?
Pitch Change?
Old 07-26-2014 | 07:21 AM
Default Pitch Change?
Basing this on a 4 or 5 blade prop in general terms,
How much pitch can be added to a prop?
In terms of real change in the pitch?
By other tricks that will change the effective pitch of the prop?
RaggedEdge is offline
Old 07-26-2014 | 12:35 PM
1" up or down is the general rule. Maybe another 1" of effective change for some cupping and rake adjustments
Griff is offline
Old 07-28-2014 | 02:35 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Agreed. The smaller the overall blade area of a given propeller the harder it is to adjust the pitch. Blade area near the root can not be bent.
Cup adjustments can "trick" the prop into about a 3" change but the performance gains are different than actual pitch changes.
Brett
[email protected]
bbladesprops is offline
