Mercury efi to holley efi. How to get the correct throttle throw.
I haven't got around to correcting this issue on my boat after going to holley efi. Is there a adapter to get full throw? Half throttle is full throttle right now. Thanks
Shifters don't have other throws on them , that was my first guess. Don't have a pic but my current setup is this adapter on the t/b. Yes 1000cfm
http://www.michiganmotorz.com/thrott...FZTm7AodxnIAug
After doing the same swap as you, I ended up with the same issue. The problem was solved by making an extension bracket out of plate aluminum and bolting it to the throttle body lever assy.Then attaching the cable to the extension bracket. It works great, and the throttle handle moves full sweep now.
