Wtb: Bbc heads
Old 07-31-2014 | 12:53 PM
Default Wtb: Bbc heads
Looking for reasonably priced oval port not peanut
048 or 781 or 279 prefer complete marine drop in ready.
Thank you
GLENAMY 242SS is offline
Old 07-31-2014 | 03:33 PM
Sick Stinger's Avatar
Brotherhood #1
Why not a nice pair of 188 square port with all good stuff?
Sick Stinger is offline
Old 07-31-2014 | 04:02 PM
Good question simple awnser
1. Not enough motor to support them
2. Don't want to replace the new intake manifold i just bought
3. This is a 1-2 season motor i need to replace alpha with bravo drive before adding large power
thank you for your interest typically for a build your idea would be the way to go.
Old 08-02-2014 | 05:20 PM
U can use oval port manifold on rec. Heads will work fine. As far as enough engine u should be fine. I would def. Go with rec port there is no reason not to
freekazoid is offline
Old 08-03-2014 | 08:06 AM
Thanks to all i just bought a clean set of 781's for $250 i want a small chamber to help compression, or lack thereof. Off to the machine shop for larger valves and a shave. Now 2.18 or 2.25?
Old 08-03-2014 | 08:56 AM
It all depends on cam, intake and carb. Don't go too big or you'll lose velocity and chamber fill.
Jonesyfxr is offline
