502 mpi no inj. pulse on 1/2 the inj ? >
Old 08-09-2014 | 11:40 AM
Default 502 mpi no inj. pulse on 1/2 the inj ?
I was out testing props and went to accelerate one more time and one eng. dropped rpm. I checked and swapped everything you can think of except the whole distributor. ECU, Module, Coil. Checked ever ground I could find. The only thing that I didn't was the pickup coil in the distributor. Got to freekn hot out now.
Any Ideas??
Velocity Tom is offline
Old 08-09-2014 | 12:04 PM
I did find the coil wire arcing back to the coil itself. I was thinking it could of took out something in the distributor but that was not the case. The engine is grounded good. I'm out of ideas.
Old 08-09-2014 | 12:51 PM
Injector harness issue?
Trash is offline
Old 08-09-2014 | 12:54 PM
MER Performance's Avatar
The injector harness has 2 positive key-on for banks of injectors. Might want to check pin outs first for 12 volts.
MER Performance is offline
Old 08-09-2014 | 01:56 PM
That's the way im leaning that its a wiring issue. It lost power all at once
Old 08-09-2014 | 02:42 PM
Any Ideas??
Unplug the knock sensor and see if it comes back.
AllDodge is offline
Old 08-09-2014 | 03:18 PM
WY the knock sensor? I thought that controlled timing?
Old 08-09-2014 | 04:09 PM
Tom.....
I have diacom. You can borrow the lap top and the cable.....I can meet you at the shop....
commandersander is offline
Old 08-10-2014 | 08:05 AM
My thought is, if the knock sensor picked up a knock it would retard your timing. If retarded you would suddenly loose power. Mine did it and I couldn't get above 3000 rpm
AllDodge is offline
Old 08-10-2014 | 08:08 AM
Thanks Commander ! My bud has one and everything is ok on that end.
