Ran truck and trailer over the scales today >
Old 08-10-2014 | 09:07 PM
Expensive Date's Avatar
Default Ran truck and trailer over the scales today
[ATTACH=CONFIG]527668[/ATTACH]
2008 GMC DRW crew cab diesel 4x4 with aluminum trailer and 35 Fountain EX. Coming back from Buffalo so did have like 300 lbs of extra boat and trailer parts.Truck was loaded with fuel, boat has about 60 gallons.
Attached Thumbnails Ran truck and trailer over the scales today-img_20140810_200128_564.jpg
Expensive Date is offline
Old 08-10-2014 | 09:18 PM
yep
tnc110 is offline
Old 08-11-2014 | 07:31 PM
Wow that really was a 20,000 lb set up!
Jupiter Sunsation is offline
Old 08-11-2014 | 08:55 PM
Have you run the truck over empty? Do you know what the truck axles weigh without the boat?
Chart is offline
Old 08-11-2014 | 09:01 PM
So much for the thought that Fountains are fast because they are light..
boatnt is offline
Old 08-11-2014 | 09:28 PM
It`s a 11K boat with trailer, my 33Outlaw was 12K with steel trailer.
ICDEDPPL is offline
Old 08-11-2014 | 09:33 PM
Yea but the 35 fountain is only 30 feet long.
Wildman_grafix is offline
Old 08-11-2014 | 09:40 PM
ok so you had a heavy trailer,,whats your point?
boatnt is offline
Old 08-11-2014 | 09:42 PM
Im surprised a 2005 35 Fountain weighs that much. Just guessing but prob around 1k lb tongue weight? 12k lbs with only 60 gallons of fuel in it, on a trailer which looks to be aluminum? Thats not a light boat imo. Well, for what you would think a modern 35 Fountain at least. Prob close to 10k lbs fully fueled on the water.
MILD THUNDER is offline
Old 08-11-2014 | 09:44 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Tim's welded aluminum Manning trailer probably rivals the weight of a steel trailer. It's built really stout.
Next time, drop the tongue stand on the scale, with the truck off the scale and get the weight differential. That's a better figure to know.
Sydwayz is offline
