aftermarket mechanical fuel pump
Is there supposed to be a direct swap aftermarket mechanical fuel pump for the Mercruiser serpentine driven fuel pump system? I bought a Holley marine not thinking anything of it, and the arms are clearly different? Am I just supposed to modify the arm? Or is there a different pump to get?
Thanks,.
Thanks,.
I actually thought about doing that. Is that actually what you're supposed to do?
I've been doing some more searching - is the Mercruiser 454 pump actually a SBC pump? The arms look similar to that of a SBC fuel pump.
Thanks!
http://www.airtexproducts.com/
I bought a Carter from Summit Racing for my 350 Mercruiser. It had a different arm, but bolted right on and my engine runs flawlessly. I will be putting it in the water tomorrow, I'll let you know how it runs.
