motor dies when putting it in gear >
Old 08-16-2014 | 06:47 PM
Default motor dies when putting it in gear
500efi bravo drive. All the sudden it started dying when I put it in gear both forward and reverse. Runs fine other than that. Idle is 800 I believe.
Drock78 is offline
Old 08-16-2014 | 07:02 PM
Dies like its ignition (like turning off a switch) or load from the drive pulls the rpm's down until it stalls?
502ss is offline
Old 08-16-2014 | 07:10 PM
i had that problem earlier this year but it was the carb .... does the 500efi have a shift interrupter on it ?
state1310 is offline
Old 08-16-2014 | 07:50 PM
I guess I didn't pay attention to that. I was trying to go through things in my head that it could be.
Drock78 is offline
Old 08-16-2014 | 09:03 PM
More than likely, the IAC is either bad or stuck. You can try pulling it out and cleaning it with some carb cleaner. The get gummed up with oil, belt dust, etc. and it makes them stick, especially when hot. Remove the IAC and clean off the pintle (plunger) and the bore that it sits in. It is mounted in the throttle body right on the front of the engine. The IAC is closed when idling in neutral. When you put it in gear and the load increases, the IAC must flow all of the air to keep the engine running. If it doesn't open, the engine will die.
Eddie
Young Performance is offline
Old 08-16-2014 | 09:06 PM
whats an iac?
stimleck is offline
Old 08-16-2014 | 09:07 PM
Originally Posted by stimleck
whats an iac?
Idle Air Control
endeavor1 is offline
Old 08-16-2014 | 09:30 PM
whats an iac?
Idle Air Controller. It supplies, basically, all of the additional air that an engine needs when the load increases from putting it in gear. The throttle blades are just cracked open allowing enough air through so that the engine idles in neutral. However, it can't allow enough air when the load increases. That's where the IAC comes in.
Eddie
Old 08-16-2014 | 11:43 PM
Thanks Eddie. I kinda thought that might be the problem but wanted to get other options before I tore into it tomorrow
Drock78 is offline
Old 08-17-2014 | 12:05 AM
Lightbulb
If you just left it in neutral you wouldn`t have this problem
ICDEDPPL is offline
