Bow light thru hull drain??? >
Old 08-20-2014 | 03:02 PM
Default Bow light thru hull drain???
I'm looking for the flush drain fitting on the bow of a 33 or 37AT. My anchor locker has a 5/8 opening and a flange that hangs over to hide it. When I back the boat off the trailer the flange snags my bow stop, I want a flush mount fitting but an having bad luck finding one. Anyone know where I can get the thru hull fitting that are on the ATs
s022mag is offline
Old 08-21-2014 | 09:02 AM
I thought that was a vent, not a drain....
Pwraddr is offline
Old 08-21-2014 | 09:50 AM
Maybe but either way I want something like that. All the thru hull fittings that are like a mushroom design require a 1" opening. Mine is on 5/8 and really don't want to drill any larger.
s022mag is offline
Old 08-21-2014 | 04:56 PM
ActiveThunder's Avatar
It's a drain for your pop-up bow light.
ActiveThunder is offline
Old 08-21-2014 | 09:01 PM
Ahh, gotcha! Assumed (I know ass-u-me) it was a vent.
Pwraddr is offline
Old 08-22-2014 | 08:06 AM
Yeah so where would you guys find a replacement at?
s022mag is offline
Old 08-26-2014 | 01:46 PM
Not sure what the newer AT's use, but most fuel vents are 5/8"
Maybe these??? http://www.cpperformance.com/p-348-b...l-vent-58.aspx
Griff is online now
Old 08-26-2014 | 09:45 PM
The drain on the newer style pop up lights is pretty small. The hole is at best 1/4" with a flush collar around it that's not much more than an 1/8" ring. It's a pretty stealth looking piece.I'm pretty sure the pop-up light is from Accon, not sure the drain is theirs though. Why don't you just get it over with and order a new Active Thunder? It'll come with it already installed, what could be easier?
509 SC is offline
Old 08-27-2014 | 07:31 AM
http://shop.acconmarine.com/products...up-cleats.aspx
Old 09-03-2014 | 11:09 PM
I do like the AT37s but just bought this one so it will be a while before I buy again. Thanks for the sites though.
s022mag is offline
