Bilge pump in Fountain left running dry- are they toast? >
Old 08-26-2014 | 07:01 PM
Default Bilge pump in Fountain left running dry- are they toast?
The bilge pump switch on the dash was accidently flipped last night while putting on the cockpit cover and I discovered it running the next morning (about 12 hrs+). There was no water in the bilge and it ran dry the entire time. Is it ruined like a seawater impeller or are they designed to run dry? I will be pulling the boat out of the water in a few days and will run water into the bilge to see if they all (I have 3 pumps) work but would like to know if I should be looking at ordering replacements now.
gregm35 is offline
Old 08-26-2014 | 07:33 PM
Rookie's Avatar
It should be fine. They are not a rubber contact impeller like a sea pump impeller. They are more like a screw drive that conveys water. They test run them dry for hours in quality checks. At least the attwood ones are.
Rookie is offline
Old 08-26-2014 | 07:44 PM
On Time's Avatar
Get the make/model and look up on the internet. Many modern pumps can run dry without damage. If unable to find out call the manuf.
On Time is offline
Old 08-26-2014 | 08:24 PM
The pumps are in a 2005 Fountain so I assume relatively modern and surprisingly sounded normal when I caught it the next day. In any event I'll test them in a few days but I'm feeling some relief with your comments. thx
gregm35 is offline
Old 08-27-2014 | 02:05 PM
I test mine at the beginning of each season, and at some point midway throughout the season. I was quite surprised that the bilge pumps are so quiet when operating.
Why wouldn't it be a good idea to have an alarm on the pump - that way you know if/when its running? I guess on some boats it would be going off all the time, but....
ALL_IN! is offline
Old 08-27-2014 | 02:29 PM
Rookie's Avatar
When my pump is on the light on my switch goes on whether by dash switch or float switch.
Rookie is offline
Old 08-27-2014 | 03:42 PM
Yes, mine does too - but if putting your cover on, and accidentally bump the switch, you may not notice.
ALL_IN! is offline
Old 08-28-2014 | 08:51 AM
put plug in put some water in and see if they pump ok...
ezstriper is offline
Old 08-28-2014 | 09:39 AM
Not exactly on topic, but I have always hated where they mounted the pump on my boat. They have it mounted way up under the front of the engine. When it runs, it still leaves several inches of water in the bilge under the oil pan. Only thing I can figure is they were worried about clearance with the oil sump.
Budman II is offline
Old 08-29-2014 | 12:09 AM
I had one of mine in my Fountain run for a weekend once, came in my shop on a monday morning & herd a noise, the starbord pump was switched on & it ran all weekend. It still works fine, and that was two years ago.
Bawana is offline
