I need stern lift >
I need stern lift
I need stern lift
Old 08-27-2014 | 04:22 PM
Default I need stern lift
Hi, I am running a 28 ft Scorpion rigid inflatable with 2x300 verados spinning 21p Rev4s.
Recently repowered the boat from its 2x250 hpdi's (blew them) and the extra weight of the verados squats the stern down - It's a light and slim hull, less than 3000 lbs and 8 ft across, really designed for lighter engines...
I have the engines at the right height (I think, or maybe a touch too high) and get a prop slip of 10%. Boat reaches 67 mph at 6200 wot, and cruises at 44 mph at 4500 rpm.
I love the speed and love the engines, but I need props that would lift the stern more. Do you have any suggestions? How about 5 blades?
Andis is offline
Old 08-27-2014 | 05:09 PM
Contact B Blades, they will guide you in the right direction.
Jonesyfxr is offline
Old 08-27-2014 | 05:24 PM
I had a giirl ask me about stern lift once... I told her to try spanx...
Anybody ever tried partially filling a rib with helium???
phragle is offline
Old 08-27-2014 | 05:38 PM
SB
Thanks Phragle - High Pressure Ice Coffee out my mouth. JAckass ! LOL !
SB is offline
Old 08-27-2014 | 07:02 PM
Lol
Old 08-27-2014 | 09:21 PM
I prefer hydromotive, everything they have suggested has worked for me.
540apache is offline
Old 08-27-2014 | 10:34 PM
Have you tried to spin the props inward?
turbo rr is offline
Old 08-27-2014 | 11:11 PM
phragle is offline
Old 08-28-2014 | 10:29 AM
Helium won't work. It's small molecule size escapes the tube seams too quickly - at the pressure these are supposed to work. Some people use Nitrogen and report 3-4 kts pickup.
Andis is offline
Old 08-28-2014 | 10:31 AM
How would I do that?
Why would it work?
Andis is offline
