First ride with the 1500 HPs >
Old 08-27-2002 | 06:34 PM
36spectre's Avatar
Registered User
Default First ride with the 1500 HPs
Well about an hour ago we tried our first dial in with the 1500 Hp bandit racing engines. The motors ran too well. With the 17.5 5 blade 35 pitch props the boat lifts the transom several feet out of the water which was a little scary at 125mph. The gear ratio is way off, should be 1:33 or 1:25 and not1:50. Still ran 125mph at 5000 RPMs and 100 at 4000 RPMS. This two year project is not done yet. I want to use the boat this weekend so I'm on the hunt for a set of 16X35 4 or 5 blades to try . I know that it wont be perfect till I change the ratio. Any input would be appreciated.
36spectre is offline
Old 08-27-2002 | 07:22 PM
36spectre's Avatar
Registered User
ttt
Old 08-27-2002 | 07:33 PM
Default Crazy
36- your friggin nuts!!
Keep up the updates!!!!
Maximus
Maximus is offline
Old 08-27-2002 | 07:56 PM
H2Xmark's Avatar
A gear change would be a big help with the power you have, keep us posted
H2Xmark is offline
Old 08-27-2002 | 08:04 PM
36 u may have to look into some avionics soon.The FAA might want u to file a boating plan before leaving the dock.
Donzi Corleone is offline
Old 08-27-2002 | 08:05 PM
shifter's Avatar
www.weismann.net
1.5 ratio will not last long. Change it before it breaks. With 1200 hp torq motors one went in 22 hrs.You are on a time bomb with that amount of power anyways. 1.24 will last about 1 year with care.
good luck
pat W
shifter is offline
Old 08-27-2002 | 08:45 PM
36spectre's Avatar
Registered User
Shifter, heard that the 1:5 wont last and have probably decided that I should go for the 1:24. Anyone delt with Randy at Corba for drive work?
Old 08-27-2002 | 09:18 PM
bob
Charter Member #40
Otto / might try Matt at JT's drive shop at 305-949-2677.
bob is offline
Old 08-27-2002 | 10:31 PM
36spectre's Avatar
Registered User
ttt
Old 08-27-2002 | 10:36 PM
aussie
AWESOME !!!!!
Post a video !!!!!!!!!
cheers,
Dave
