Do props come perfect from the factory? >
Old 09-14-2014 | 07:42 PM
Default Do props come perfect from the factory?
Do props come perfectly tuned and balanced from the factory, or are the tolerances of mass production loose enough that almost any prop would benefit from a tune even when brand new?
Baja Rooster is offline
Old 09-15-2014 | 12:08 AM
BUP
No and basically no 2 props are the exact same as being labeled the same model, diameter and pitch. There is a certain amount of handling, temperature, curing, hand finishing and final finish that can vary from prop to prop during manufacturing from start to end. Also some added info at one time Mercruiser / Mercury Racing even had a Service Bulletin about stamped pitch on the props versus true pitch differences.
BUP is offline
Old 09-15-2014 | 01:30 AM
No, not perfect. They are "within specs"
Griff is offline
Old 09-15-2014 | 06:46 PM
Those are the answers that I was pretty much expecting. Thanks!
Old 09-16-2014 | 10:54 AM
bbladesprops's Avatar
Offshoreonly Advertiser
There are a number of reasons the box stock propellers have variations in out of the box new form.
One of the biggest issues in my opinion is balance. Stock props are balanced prior to the polishing method of drag finishing. Because of this, it is rare to have a perfectly balanced propeller out of the box. This is why we high polish all our polised requests by hand.
Brett
[email protected]
bbladesprops is offline
