525-w/3.3 Whipples
Old 09-25-2014 | 04:09 PM
Default 525-w/3.3 Whipples
Looking at a Cig with this set up- anyone have any experience with this particular package/set up as far as dependability??
Thanks for your help!!
Unlimited39 is offline
Old 09-25-2014 | 05:02 PM
If it's the boat at LOTO, then it looks like a really sweet ride. I don't think the XR drives would do too well behind 750+hp though. If I was buying the boat I would budget for a drive swap to Imco SCX's.
Good luck - I really like that boat.
freshwaterfiend is offline
Old 09-25-2014 | 05:16 PM
Smitty's Avatar
Dependability depends on who did the installs. As far as the blowers themselves, they are pretty much bullet proof. Great systems, no idle issues and tons of torque. I will tell you this though, if you buy the boat, immediately change the gear lube in the blowers. then check the level on a monthly basis. if it gets too low, it will burn up the gears inside. Also on the 525's, they have some header issues. Do a search here about it.
Smitty is offline
Old 09-26-2014 | 07:00 PM
Thanks for the Info!!
