Remote oil filter mounting heigth? >
Old 09-28-2014 | 08:51 AM
Default Remote oil filter mounting heigth?
I am cleaning up bilge area and want to remove the oil filter from the exhaust and mount on transom. How high above engine can i mount it? I am woried i may create an oil flow problem with the extra height, about 1 1/2' above it's stock position. Any recomendations or experiences?
Thanks in advance.
GLENAMY 242SS is offline
Old 09-28-2014 | 08:59 AM
Tinkerer's Avatar
Height wont mater. hose length will mater.
Tinkerer is offline
Old 09-29-2014 | 07:53 AM
I mounted mine on the transom just outside of the engine, did upgrade all the lines, fittings, adapters, and cooler..merc stuff is pretty much junk..
ezstriper is offline
Old 09-29-2014 | 09:15 AM
Mine is on the transom as well at about cylinder head height with -10 lines. It allows me to use an oversize Donaldson Filter #P550832, which keeps the oil super clean.
ThisIsLivin is offline
Old 09-29-2014 | 06:47 PM
Thanks for the resopnses.
Old 09-29-2014 | 09:03 PM
if you start over with new hoses&fittings go with -12.very little resistance to flow.
mike tkach is offline
