BBC 174 supercharger >
Old 09-30-2014 | 08:17 PM
Default BBC 174 supercharger
Comes with intake, charger, thermostat relocater, belt, pulleys. Everything is there to bolt on and go. I bought for my boat but going a different direction.
$1600 plus shipping
bigbird241 is offline
Old 10-02-2014 | 06:02 AM
Also comes with Nickerson dominator carb
Old 10-08-2014 | 12:16 PM
Have a number? Guy at work looking for one
dsmawd350 is offline
Old 10-10-2014 | 09:53 AM
Hey big bird is it for oval or square port? Thank you
georgie1 is offline
Old 10-10-2014 | 11:21 AM
Square
Old 10-10-2014 | 11:28 AM
Do you know if that's big enough for a 502 with grumpy jenkins 345 cc intake runners? Does anyone here know? If it will work I'll take it. I see 177 's also for bbc
georgie1 is offline
Old 10-10-2014 | 12:00 PM
We put a 174 blower on a 516 last year and a 509 this year. With the pulley that came with them the blower would only make 1/2 lb of boost. With the smallest pulley we could get it will make 3-3/12 lbs.
That's with gm 088 heads.
Baja226sport is offline
Old 10-10-2014 | 12:07 PM
Ok so probably not enough boost then. Thank you
georgie1 is offline
Old 10-10-2014 | 02:12 PM
From what I was told by the guy at the engine shop[ when the one engine was on the dyno the heads do not determine the boost. It is the engine's displacement vs. the blower's displacement and rpm.
Old 10-10-2014 | 09:50 PM
I personally feel blower size is relevant to cubic inch, but also HP level. A 454 with peanut port heads, stock manifolds and a rv cam wont require the same blower as one with fully ported cnc heads, 700 lift cams, and headers. A poor flowing 454 engine will see higher boost than a good flowing 454 at xxx drive ratio.
MILD THUNDER is offline
