Swim Platform boarding handle location??? >
Old 10-01-2014 | 02:46 PM
Dean Ferry's Avatar
Default Swim Platform boarding handle location???
Q,
I have 2 locations I'm looking at for mounting a 10" grab handle for the swim platform/boarding ladder on the Talon. 1st is upper on the engine hatch, which will give more reach, and 2nd is lower with less reach but is mounted to the hull deck... The engine hatch is thick enough for the handle to be mounted to, I'm just trying figure out which will work best.
Thanks,
Dean ATTACH=CONFIG]530203[/ATTACH][ATTACH=CONFIG]530204[/ATTACH]
Attached Thumbnails Swim Platform boarding handle location???-upper-boarding-grab-handle-location-talon-25.jpg   Swim Platform boarding handle location???-lower-boarding-grab-handle-location.jpg
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 10-01-2014 | 03:57 PM
F-2 Speedy's Avatar
I think the lower mount, blends in better, Id stay off the hatch
F-2 Speedy is offline
Old 10-01-2014 | 04:08 PM
Also looks like there are snaps on the engine hatch??? So having the handle above your snaps would no doubt interfere with any cover that uses those snaps, unless of course, the cover was modified after the handle is in place.
low_psi is offline
Old 10-01-2014 | 04:16 PM
If you mount it on the lower spot will the hatch hit it when you open the hatch?
E Colby is offline
Old 10-01-2014 | 04:50 PM
Think about docking an rafting up with other boats. How far does this stick out from the boat? Good luck. Artie
akaboatman is offline
Old 10-01-2014 | 04:52 PM
Don't go too low.
My boats rear handle is too low, if you are in the water it is useless. I have a rope tied along the back pad to get out of the the water and back into the boat.
Nate5.0 is offline
Old 10-01-2014 | 06:52 PM
Take a pic of the hole back of the boat to get a better idea
1989mach1 is offline
Old 10-01-2014 | 09:31 PM
Wobble's Avatar
SORE MEMBER
Jump in the water and see where your wife can reach comfortably.
Wobble is offline
