aeration tubes or not? >
Old 10-06-2014 | 07:32 PM
Default aeration tubes or not?
as I am setting up the 32B questions come up.....pros & cons of aeration tubes?
also, anyone have any experience with these.....
http://www.offshoreonly.com/classifi...o58433-en.html
They definitely look kewl, but how do they hold up under high speeds and the stress put on them? I wouldn't expect them to flex much.......
thedonz is offline
Old 10-06-2014 | 10:19 PM
turbo94gto's Avatar
Ha ha I was getting close to asking the same question. I know my outboard boat would not get on a plane without some ventilation. I don't want to run the tubes if I don't have to.
turbo94gto is offline
Old 10-07-2014 | 06:35 AM
I have the teague brand installed on my 32B. I run a set of 800NA motors and they don't make much torq on the low end to spin my props to get on plane so I installed the vent tubes and the boat gets on plain no problem now. Well werth the money for my setup.
raymo1979 is offline
Old 10-07-2014 | 07:02 AM
Peter designed an automatic vent tube
http://www.offshoreonly.com/forums/g...ml#post4069859
noli is offline
Old 10-07-2014 | 10:29 AM
raymo,
post picks of your boat and setup, we'd love to see it
thedonz is offline
Old 10-07-2014 | 04:30 PM
turbo94gto's Avatar
Ray, Would it not get on a plane at all?
Old 10-07-2014 | 05:20 PM
Brandon I think it's time to change your avatar what's wrong with you. Going on the 2nd Skater and still have the Eliminator. What are you waiting for ? 3rd ones the charm haha
SkaterMike82 is offline
Old 10-07-2014 | 07:17 PM
When I got my Skater it had Coan 2 speed transmissions so it got on plain easy with the low gear. I got rid of the 2 speeds and put a set of Bam in. So I lost the low gear the boat would get on plain but I had to work it put the drives up tabs down till the props started to spin then lower the drives raise the tabs. I got sick of that really quick and installed the air tubes she gets on plain now no problem 5 people full tanks I cant be happier.
Old 10-08-2014 | 12:11 AM
All I can say is don't buy those carbon fiber ones. Over priced!! Just the regular ones will be just fine
precisiondetails is offline
Old 10-08-2014 | 05:18 PM
turbo94gto's Avatar
Well then I better try to get some on before I even water test the thing. Little 525s in a 36 will definitely need them if you were having a hard time with 800s.
