Countdown To Key West: New Talbot Excavating Cat to Debut
Correspondent
One of the more highly anticipated new offshore raceboats of 2014 will hit the water in Key West, http://speedonthewater.com/in-the-ne...g-cat-to-debut
found this on Grant's Signature Racing Facebook
what is it, and what does it do?
Photo Credit: https://www.facebook.com/GrantsCustomRigging?fref=photo
The stainless plates with welded washers bolt on to the outside of the jackplates to lock them into position. They replace the older fender washer setup that has been used for years.
what is the basic purpose of the black unit? is it to increase distance between engine and the transom, like a spacer?
also, what if there is no jackplate used with the outboard ? Can the black unit still be used between engine and transom??
Yes they are spacers, he has a couple sizes available. Get in touch with Grant if you want a pair or two. 954-249-9732.
