Hydraulic steering ram leaking??? >
Old 10-21-2014 | 07:46 PM
Default Hydraulic steering ram leaking???
I've got one last trip out on the boat coming this weekend and I noticed that my port side ram for the hydraulic steering is leaking. My fluid reservoir is low so I figure I better add some just not sure what it takes. Also can the ram be rebuilt or does it need to be replaced. Or should I not boat with it leaking at all until rebuilt/replaced?
s022mag is offline
Old 10-21-2014 | 09:55 PM
I would find a local hydraulic shop they should be able to rebuild the ram. I went thought the same thing last year and it was around $200 per ram here in north Texas.
Donzi1979 is offline
Old 10-21-2014 | 10:02 PM
Shouldn't be very hard to rebuild. Easier than a shock, no shim stacks to deal with, just o-rings and seals.
phragle is offline
Old 10-22-2014 | 01:30 AM
Fill reservoir and go boating.
The ram can be rebuilt/resealed by the manufacturer or most likely locally.
Griff is offline
Old 10-22-2014 | 06:54 AM
Thats the answer I like. But will probably look around to see who can rebuild it. What kind of fluid?
Funny how I noticed it must not be real bad. I lowered the drives to get the boat to fit in storage so gravity must be helping. Then I wondered why I didnt see a leak when it was in the water? Must be enough water pressure 12in down that doesn't allow it out.
s022mag is offline
Old 10-22-2014 | 08:05 AM
vintage chromoly's Avatar
I took mine to a local heavy equipment / agricultural cylinder shop.
Very basic prcedure to rebuild a hydraulic cylinder.
75 bucks each. New seals and o-rings and a test when done.
Hardin wanted considerably more.
vintage chromoly is offline
Old 10-22-2014 | 08:06 AM
Just noticed you are in Ohio. The guy I used is just north of Ashland.
Small mom and pop shop in an old barn but they know their stuff.
Old 10-22-2014 | 08:49 AM
What kind of fluid should I use?
s022mag is offline
Old 10-22-2014 | 11:40 AM
Hydro supply in zanesville can do it. Or they probably have the parts if you want to tackle it yourself. It's not difficult at all.
RT930turbo is offline
Old 10-22-2014 | 11:41 AM
My latham uses ATF. The old steering on the cig uses 10wt hydro oil... Is the fluid red?
