Best big sit down vee
Old 10-22-2014 | 10:40 PM
Default Best big sit down vee
LOOKING FOR BIG SIT DOWN VEE INPUT
Starting from the Gladiator up, what would be top boat to run offshore new jersey and inner coastal. Is there a such thing as too big??
My 370 is on the large side running around south jersey chanel but very comfortable. Is 42' getting little long?
The ocean is less than perfect and having a 42' + boat has me thinking smoother rides more often.
One other factor, trailering to destination areas. The main dockage will be lagoonfront on a lift but considering a couple destination trips a year. How difficult trailering a 42'+ compared to 38'?
Appreciate you experiance and opinions
370ss500efi is offline
Old 10-22-2014 | 11:03 PM
I have a 51 outerlimits I'm going to be selling soon.
marine concepts is offline
Old 10-23-2014 | 08:06 AM
Any of the OL GTX models. If you want one with milder power look into a 38 Donzi ZRC or the 42 fountain poker run.
Donziben is offline
Old 10-23-2014 | 08:13 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
388 Skater V sit-down; world record holder. (I thought they were building a 40-something too?)
Various Cigarette one offs including the Kilo boat, the "Skaterette", and several 45' Cigaratte Maximus models.
As mentioned: 42 Fountain PR and Donzi ZRC
Dragon/GTMM 39
As mentioned. several GTX/sit-down models from Outerlimits--however, the epoxy and alternative hull construction models have been described as harsh, stiff, and unforgiving in ride. But this needs to be weighed in your own ass' opinion.
Sydwayz is offline
Old 10-23-2014 | 08:20 AM
You wrote more, but that's what registered in my sick mind.
End hi-jack.
Speedracer29 is offline
Old 10-23-2014 | 09:16 AM
OL40SVX's Avatar
There is only one record holding sit down Vee bottom and it is our Outerlimits SV43 with the Kilo at 180mph.
OL40SVX is offline
Old 10-23-2014 | 09:19 AM
A glads a great choice. Mine eats up the rough and rides flat and smooth.
Actually measure 36'11" and if they had a comparable busle would be about the same wave crushing running surface as other brands 42' boats.
Good luck on your search your on the right track IMO on getting into one sweet powerboat!
offshorexcursion is offline
Old 10-23-2014 | 09:23 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Some good reading for you:
http://www.boatingmag.com/new-bermud...e-record-set-0
Sydwayz is offline
Old 10-23-2014 | 09:34 AM
I keep coming back to the gladiator, it is just a bad A** looking boat. How is the ride offshore compared to a top gun?
Old 10-23-2014 | 09:41 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
http://www.offshoreonly.com/forums/g...-released.html
http://www.offshoreonly.com/forums/g...check-out.html
Amazing boat:
[ATTACH=CONFIG]531386[/ATTACH]
Sydwayz is offline
