Winterizeing for a week or two
I just purchased a formula 242 with twin 5.7s. The boat is at my parents house in detroit but I am in miami. I am bringing the boat here in 2 weeks or so but I'm worried they may have freezing temps before I get up there. My dad is to old to be hanging around under the engines trying to drain them. I have never owned a boat up north so I have never had to winterize before, not sure what all needs to be done to get all the water out. Im trying to not have someone winterize the boat for a few weeks of cold. I've been looking at magnetic block heaters, put one on each block and plug it in, should be enough to keep the block from freezing. Has anyone tried this, did it work? Any thoughts or ideas appreciated. Do I need to worry about the outdrives freezing as well?
I'll disagree. We've had frost in Virginia already, and I know Detroit has been colder than us.
Have your Dad hang 2 trouble lights in the bilge with 100W bulbs. That will keep the engine compartment a good 10 degrees warmer. Just make sure they do not contact anything.
1 light would work, but if it burns out, then you could be hosed. That's why I suggest 2.
I actually use two of the clamp on work lights from Lowes/Home Depot.
Put it in the water, you will have nothing to worry about. And temps that cause a frost aren't going to crack anything. Even nights that get into the high 20's are fine. It is really the amount of time spent below freezing that matters more. This time of year you will be just fine.
