Buffing Gelcoat
I plan on buffing my boat this winter. I have a partial wrap on the boat. Any ideas of what to put over the edges of the wrap so the buffer doesn't mess it up. I was thinking painters tape but I did not want that to peel up the wrap when I pull it off. Has anyone else ever done this?
Thanks,
Blake
Thanks,
Blake
the blue painters tape is pretty weak stuff, the glue is like a friggin post it note lol. I would think regular 3M green should work good and if your wrap was properly applied I wouldnt think you should have a problem pulling it off.
08 OPA High Points Champion
Hey Blake, tried to RE your PM and got a "pm box full" thingie . . . so hear ya go
Yep actually i have a compound i use for exactly that, light oxidation. Fountain of Youth Restore has a compound called Totally Buff that is amazing, not a snake oil product just a well thought out marine compound. Its a diminishing compound that works itself down to a finer polish as you go and it has an odd/cool property that lets it clean itself out of a wool pad (by the way wool ONLY for gelcoat, no foam) As you work the buffer it kinda balls up and flings out of the pad and never gums up. I have done three thirty eights with the same pad and never spurred it a single time pad. After hitting it with Totally i finish up with either Vitreo or Awesome wax (also from FoY) heres a link. All there stuff is great its all i use in my shop
http://www.fountainofyouthrestore.com/products.html
not sure if you saw this thread but theres some good info . . . .
http://www.offshoreonly.com/forums/f...vibra-cut.html
good luck man and let me know how it goes
Originally Posted by CBlakeNS
Dave,
My buddy Chris "badmonkey" had mentioned your name. He said you had a product you typically use that keeps a very nice shine on your boat. I will attach a picture of my boat. I was wondering what your process would be. I have a porter cable rotary buffer. The gelcoat is clean looking....it isn't really chalky it just has a dryer feel to it. I want it almost slick like a bowling lane. I was going to use either 6" blue foam cutting pads or thin purple foamed wool pads with marine 31 all in one gelcoat polish and wax. Let me know what you think.
