My 502 got Wet!!!
Old 10-30-2014 | 05:42 PM
Default My 502 got Wet!!!
Well this just sucks!
My lift busted while I was away for the weekend and the aft of my 1998 Baja 502 EFI went under (fresh water). I guess the good part is it wasn't running and it was fresh water.
Am I looking at a total rebuild? There is no water in the Oil at all.
I haven't touched it yet, so I dont know if it will start or turnover, I wanted to get some advice before I tried to fire it up.
Cheers!
VancouverMark is offline
Old 10-30-2014 | 06:10 PM
Take the plugs out and turn it over or turn it over by hand backwards a few times then start it.
Black Baja is offline
Old 10-30-2014 | 06:25 PM
vintage chromoly's Avatar
How far under?
vintage chromoly is offline
Old 10-30-2014 | 06:26 PM
Sydwayz's Avatar
Forum Regulator
How far under is the water line? My 468 got wet in my jet boat when I lost a main cooling line. Water was over the starter and the oil pan. Once dried out, I didn't even lose the starter.
Sydwayz is offline
Old 10-30-2014 | 07:05 PM
WTF, lift failed, and boat leaked. You had a bad week!
Did any electronics get wet? If so you probably can't just start it.
But since the engine has no water in the crankcase you might have dodged that bullet. So remove the spark plugs and spin out any water in the combustion chambers right away. Doesn't have to turn backwards, the plugs are out. If you get water out of the spark plug holes, oil the combustion chambers and valves. Then if you can't start it you can at least preserve the engine til you can fix the electrics. That can be done by bypassing the ignition either with a remote starter button or by pulling your kill lanyard so you can crank it over without starting. The remote button is best because you won't energize the fuel injection system. After you have cranked out any water with the plugs removed, put some fog oil in the spark plug holes and thread in your old spark plugs. Crank the engine for a few seconds (10 or 15ish) while fogging through the throttle body. That's going to get the valves preserved.
Keep pulling the oilstick and checking, it might take some time for water to get there without running the engine.
NHGuy is offline
Old 10-30-2014 | 07:08 PM
But since the engine has no water in the crankcase you might have dodged that bullet. So remove the spark plugs and spin out any water in the combustion chambers right away. Doesn't have to turn backwards, the plugs are out. If you get water out of the spark plug holes oil the combustion chambers and valves. Then if you can't start it you can at least preserve the engine til you can fix the electrics. That can be done by bypassing the ignition either with a remote starter button or by pulling your kill lanyard so you can crank it over without starting. The remote button is best because you won't energize the fuel injection system. After you have cranked out any water with the plugs removed, put some fog oil in the spark plug holes and thread in your old spark plugs. Crank the engine for a few seconds (10 or 15ish) while fogging through the throttle body. That's going to get the valves preserved.
Thanks Guys!
The water came just below the EFI unit - to the top of the intake.
I will try spinning the water out and see what happens.
Old 10-31-2014 | 06:20 AM
Fresh water? I think it will be fine once you dry everything out.
thirdchildhood is offline
Old 10-31-2014 | 01:19 PM
My old Maxum had some epoxy on a scratch from an incident with a stump. Well apparently that stuff came off on the way to the beach because we pulled it up on the sand a little and an hour or so later there was water 6" deep in he cockpit. Rut roh.
Hit the bilge and for a while and the old 305 fired right up. Never missed a lick after that either.
Cole2534 is offline
Old 10-31-2014 | 07:10 PM
Why backwards?
cheech is offline
Old 11-01-2014 | 06:46 AM
Originally Posted by cheech
Why backwards?
Yeah, why, and won't that screw up the raw water pump impeller?
