Issue with no crank
Old 11-09-2014 | 05:44 AM
Default Issue with no crank
I am having a issue with no crank on a 04 500efi I turn the ignition key all the warnings beep and light come on. Turn to the start postion and I get nothing. I checked I have power at starter. Anyone have any other ideas? Port engine starts no problem. I have had no issues in the past with it. Used the boat 2 weeks ago now having this issue
Thanks I advance
353Formula is offline
Old 11-09-2014 | 05:50 AM
Full Force's Avatar
You have constant power? And also switched at solenoid? If so the solenoid or starter is bad... Make sure you have both power under crank, I think wire is brown or yellow
Full Force is offline
Old 11-09-2014 | 05:53 AM
I am going to check that here in a few minutes. Am I looking for power or just voltage there?
Old 11-09-2014 | 06:09 AM
Full Force's Avatar
If you have power the volts should be there, I would use a meter then you know voltage on case there is a bad connection, don't forget you need help to check switched power someone's gotta crank, I f by yourself see if volt gauge drops when you try, if it don't drop it's probably a bad connection or solenoid....
Did you pull round plug and reconnect? They get loose at tines causing issues check that first!
Old 11-09-2014 | 06:16 AM
VoodooRob's Avatar
Did you get it figured out?
VoodooRob is offline
Old 11-09-2014 | 06:17 AM
Yes I fid pull the cannon plug made sure it was clean and tight. On the slave can o use an automotive one just to get boat winterized? If that's it still checking thou
Old 11-09-2014 | 06:40 AM
Full Force's Avatar
Solenoids are same auto and boat, the starter itself is different with mesh vents
Old 11-09-2014 | 07:25 AM
Alright I checked the slave solenoid I have 12.8 volts on one side with key on and on the other side I have nothing with the key in start position
Old 11-09-2014 | 07:32 AM
Now all after the test I tried to crank engine and it cranks don't know?
Old 11-09-2014 | 07:54 AM
Full Force's Avatar
Gotta check in crank position
