anyone know where to get a new GPS speedo like this... >
Old 11-13-2014 | 09:59 AM
Default anyone know where to get a new GPS speedo like this...
can't seem to find a replacement anywhere...... sticker inside antenna says Garmin...... if any of you marine parts guys have I'll buy asap......
[ATTACH=CONFIG]532549[/ATTACH][ATTACH=CONFIG]532550[/ATTACH][ATTACH=CONFIG]532551[/ATTACH]
Attached Thumbnails anyone know where to get a new GPS speedo like this...-antenna-3.jpg   anyone know where to get a new GPS speedo like this...-antenna-2.jpg   anyone know where to get a new GPS speedo like this...-speedo.jpg
Here's Johnny is offline
Old 11-13-2014 | 12:56 PM
Hey Johnny, the problem you may run into with replacing the antenna (even if you can find one, which I think will be hard) is compatibility. I had a similar issue with a Livorsi GPS and I needed to replace both the speedo and the antenna because newer antennas will not work with the old gauges. It might be different with Gaffrig, but just double check.
- Neil
HyFive578 is offline
Old 11-13-2014 | 01:04 PM
you need the speedo or the antenna? Any gps antenna will work, if you need the speedo that is different.
pstorti is offline
Old 11-13-2014 | 05:55 PM
"IF" you replace your speedometer, don't buy the kit with the antenna. I got a new garmin GPS antenna off ebay for $75.
jtbooten is offline
Old 11-13-2014 | 06:55 PM
northernoffshore's Avatar
try kendor in wisc. (greatlakes skipper on ebay) or the marine connection in ft pierce fl
northernoffshore is offline
Old 11-13-2014 | 08:09 PM
I plan to replace both. I'm not sure which isn't working. I've read here on OSO about changing a battery but I can't seem to find one in the antenna..... Besides its yellowed and looks like crap...... Just easier to purchase the kit and replace whole thing. Any recommendations ? Or links to a good replacement ?
Old 11-13-2014 | 08:10 PM
http://www.ebay.com/itm/Garmin-Marin...item418a247a13
