Fresh water pump >
Fresh water pump
Fresh water pump
Old 11-16-2014 | 12:27 PM
Default Fresh water pump
Anybody know which freshwater pump is a direct replacement for the one on a 2000 38 special? Mine no longer has any markings on it so I can't identify what brand and model. Thanks
SNSTER is offline
Old 11-16-2014 | 02:23 PM
Pics might help with an id
First Gun is offline
Old 11-16-2014 | 02:58 PM
Do you mean for the sink?
Baja226sport is offline
Old 11-16-2014 | 03:00 PM
SNSTER is offline
Old 11-16-2014 | 03:01 PM
It is the pump that supplies both sinks and toilet
SNSTER is offline
Old 11-17-2014 | 07:25 AM
Looks like a older jabsco or Johnson pump ....shut flo aqua king would be a close replacement pump for this the 3.0 version looks to be the best fit
Old 11-18-2014 | 11:47 AM
Ok I found some info. I will update here in case it can help somebody else. The pump pictured came out of a 2000 Baja 38 Special. It is a jabsco 44010-2. This is no longer in production so I contacted Jabsco. The replacement is model 31395-0392. This is the 12v 40psi model. Hope this can help somebody else.
SNSTER is offline
Old 11-21-2014 | 05:45 AM
jvthundercat's Avatar
thank you
jvthundercat is offline
Old 12-03-2014 | 07:01 PM
Update that pump won't work. Flows the wrong way and can't be changed
SNSTER is offline
