Thunderbolt iv ignition, school please >
Old 11-16-2014 | 04:29 PM
Default Thunderbolt iv ignition, school please
I know nothing about these, please school me on these.
Are they any good? Do they contain rev limiter? If so rpm? Reprogramable?
Thank you in advance.
GLENAMY 242SS is offline
Old 11-16-2014 | 04:55 PM
I have limited knowledge of the TB IV ignition but learned a TON from this forum. I've had issues with mine, but it was a bad coil. There's no rev limiter and the modules have pre-set advance curves that are non adjustable. I went from a 22 degree module to a 24 degree module, it really woke up my 350.
Use the search function and there's a bunch of threads on it with TONS of info.
Jonesyfxr is offline
Old 11-16-2014 | 06:34 PM
BUP
No reprograming nor rev limiter built into this ignition set up. Also no putting the ignition / engine into base timing mode when adjusting timing and or setting timing. Old school set up and basically very basic and easy to work on. No knock control like the T-Bolt V offers either. A quality cap & rotor always helps as well.
BUP is offline
Old 11-16-2014 | 10:25 PM
So it seems from your input and further research here on oso that this is a reliable and adaquate component. Symplistic in nature but solid. Finally something reusable on the 454/330.
Thank you for the assistance.
Old 11-17-2014 | 09:22 AM
Just make sure all connections are tight and corrosion free. I also installed a MSD high vibration coil and installed DEI heat protective barrier behind the ignition module.
Old 11-17-2014 | 04:26 PM
Zero Patience's Avatar
Keep a spare trigger with you. They are made in China now..... Some can be 400-500 less at wfo. Some just quit, some misfire. I have switched to MSDs
Zero Patience is offline
Old 11-17-2014 | 06:38 PM
Any difference between gen 1 and gen2 other than size?
