New zero effort shifter for twins >
Old 11-23-2014 | 02:02 AM
Default New zero effort shifter for twins
Brand new in the box Mercury Racing zero effort shifter for twins.
Has trim switch. Comes with diodes and all the hardware.
650$ + ride
Attached Thumbnails New zero effort shifter for twins-image.jpg   New zero effort shifter for twins-image.jpg   New zero effort shifter for twins-image.jpg
Tigweldersm is offline
Old 11-23-2014 | 06:21 AM
i know the throttles them selves are easy to reconfigure but I wonder how hard it is to flip the trim switch to use these for a RH application...???
Baja226sport is offline
Old 11-23-2014 | 06:32 AM
paul I do believe its just as easy .mercury marine also sells just the white throttle lever with the red part switch on it .and it would go left or right
smokin' gun is offline
Old 11-23-2014 | 09:39 AM
I believe this is set up to be used in a RH application.
Old 11-23-2014 | 09:43 AM
Per your pictures the trim switch is set for your left thumb.
Old 11-23-2014 | 01:01 PM
How can you tell what is the front of the shifter? If the levers are slanted backwards then it is for a RH application? If they slant forward it is for a LH application.
Old 11-23-2014 | 01:04 PM
No. Handles always slant toward the front.
Old 11-23-2014 | 01:18 PM
Got it. So this would be for a PORT drive application. Correct.
Old 11-23-2014 | 01:26 PM
Most of the time, but they can be used either way. It really depends on the angle of the mounting location and dash layout.
Either way, they can be taken apart and reassembled in any configuration fairly easily.
Griff is offline
Old 11-23-2014 | 02:39 PM
Thanks Griff.
