Hein-Werner Bumper Jack
Old 11-23-2014 | 06:58 PM
nordic95's Avatar
Default Hein-Werner Bumper Jack
Hey guys I just purchased an old Hein Werner bumper jack and I want to make a drive installer out of it. But my question is how do I check jack oil level in this darn thing. Its air over hydraulic and I see the fill plug at the top of the jack. But no other plug to check fluid level.There is a small plug, like a block drain plug, on the air valve assembly but that cant be for oil? No dip stick or anything. I looked all over online and cant find anything about this issue.
Thanks Anthony
nordic95 is offline
Old 11-23-2014 | 10:02 PM
I can't help without a picture. All hydroic jacks have to be filled in the down position. Hope that helps.
Last edited by akaboatman; 11-23-2014 at 10:05 PM. Reason: To much jack. You don't need a air over hydraulic
akaboatman is offline
Old 11-24-2014 | 08:15 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
My friend "G" found some great info for you:
http://lmgtfy.com/?q=hein+werner+bumper+hydraulic+jack
http://www.garagejournal.com/forum/s...d.php?t=208722
http://www.garagejournal.com/forum/s...53#post3068953
Sydwayz is offline
Old 11-24-2014 | 08:24 AM
F-2 Speedy's Avatar
[QUOTE=Sydwayz;4224447]My friend "G" found some great info for you:
Impressive
F-2 Speedy is offline
Old 11-24-2014 | 09:37 AM
1 MAIDEN AMERICA's Avatar
Most jacks get filled to the plug while in the lowest position.
You'll probably want to put a regulator on it. When going up, they start slow then GO.
1 MAIDEN AMERICA is offline
Old 11-25-2014 | 08:46 PM
nordic95's Avatar
Here is the jack. Oil fill on top and no other plugs on the jack. Looked in thru plug and oil is down about two feet. But jack works fine. I can't see filling this whole cylinder with oil.
Attached Thumbnails Hein-Werner Bumper Jack-image.jpg   Hein-Werner Bumper Jack-image.jpg   Hein-Werner Bumper Jack-image.jpg
nordic95 is offline
